Discussion Groups
Robot Structural Analysis
ethor
Accepted Solution
seperate structure dialog supression
871 Views, 6 Replies
11-08-2011 11:17 PM
When I solve using the API there is a dialog that comes up if there are 2 seperate structures, as it should. It says "seperate structure, dou you want to continue? Is there any way to automatically supress this dialog or simply respond with OK without having to click on it?
Please use plain text.
Product Support
Artur.Kosakowski
Re: seperate structure dialog supression
11-08-2011 11:50 PM in reply to: ethor
Try
r.Project.CalcEngine.AnalysisParams.IgnoreWarnings = True
please
Artur Kosakowski
ovedmata
11-29-2011 12:04 AM in reply to: Artur.Kosakowski
What is the meaning of the message "seperate structure", and how do i go about solving it? I have a 2 story building with a star deck on the roof and when I run calculation i get this error. I click continue, but I have no recommendations for As min or required in slab mesh design, and i fear I am making some bad mistakes.
Also I get Execution Problem No. 3060, do you know what this is?
Thank you,
Oved
Product Support
Artur.Kosakowski
11-29-2011 12:14 AM in reply to: ovedmata
This means that (unless it is intended) you accidentally made some error (inaccuracy) in entering the model and there are two or more separate parts of the structure. After seeing this warning on the screen you can go to the node selection dialog and find that there is at least one selection group created. If you select this group you will be able to identify the separate part(s) of the model.
The 3060 error is most likely the consequence of ignoring the instability warning. If I''m correct it will disappear when you 'connect' the separate parts of your model (assuming that  the boundary conditions are as they should be).
Artur Kosakowski
ovedmata
11-29-2011 12:41 AM in reply to: Artur.Kosakowski
I understand now. I actually have to have it that way as i have columns and walls that connect only to one floor. However, this in no reason for the panel on the first floor to not be generated right? Why do you think it isn't generated?
Thanks ,
Oved
Product Support
Artur.Kosakowski
11-29-2011 12:53 AM in reply to: ovedmata
I'm sorry but I don't understand what you mean saying 'panel is not generated'. Do you mean that it is not meshed? If so, check if you defined the panel calculation model as shell.
Artur Kosakowski
ovedmata
11-29-2011 01:08 AM in reply to: Artur.Kosakowski
I did have it assigned to shell, however I had designated Shell in reinforcment as well instead of N/A. Once i did that change it now has generated mesh. I am not getting any As min or As required recomendations, I will continue to work.
Thank you for all your help!
Oved
