Discussion Groups
Robot Structural Analysis
Active Member
hussamshihabi
seismic loading
2229 Views, 20 Replies
12-04-2011 11:21 AM
hello to all
i want to ask if there is document on how does the robot analyse seismic loads is there a clear vision on how it works i mean i have been using ETABS to resolve seismic cases...so i need the philosophy in which ROBOT works to resolve the cases ... any way another question .... is there a video tutorial on modeling and analysing and designing a building with all wind loads and seismic loads application with the design of all the structural elements (shear walls , foundations , frames , bracing systems .... etc. ) thanx for all the help
Please use plain text.
Product Support
Rafal.Gaweda
Re: seismic loading
12-04-2011 11:37 PM in reply to: hussamshihabi
I am attaching 2 step by step examples how to define sesmic cases.
Then you have to create either manual or automatic combinations to be used in design.
Rafal Gaweda
Active Member
hussamshihabi
Re: seismic loading
12-06-2011 01:01 AM in reply to: hussamshihabi
thanx for the help ... is robot better for seismic analysis than etabs ?
and if u have a link of a video tutorial for the whole modeling process i would appreciate very much
thanx for ur time
Product Support
Rafal.Gaweda
Re: seismic loading
12-06-2011 01:09 AM in reply to: hussamshihabi
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tutorial-videos-for-basic-and-advanced-use-o...
Rafal Gaweda
Product Support
Artur.Kosakowski
Re: seismic loading
12-06-2011 03:00 AM in reply to: hussamshihabi
Active Contributor
vmorkunas
Re: seismic loading
07-01-2014 09:29 AM in reply to: Rafal.Gaweda
Dear support team
I found this usefull worked example posted by you, but it is done in Robot Millenium, is there anything mroe recent? I see that Robot 2014 adn 2015 has more advanced seismic analysis options? Thanks.
Member
michali
Re: seismic loading
07-02-2014 12:49 AM in reply to: vmorkunas
Hi vmorkunas,
You can find the example how to run and set up a seismic analysis in this tutorial:
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-88B74D07-4C31-46DF-B415-76658FFF549B
I hope this helps.
Ilona
Ilona Michalska
RSA Learning Experience Team
Active Contributor
vmorkunas
Re: seismic loading
07-02-2014 02:56 AM in reply to: michali
Thanks a lot, Michali, this is more or less what I was looking for!
Product Support
Rafal.Gaweda
Re: seismic loading
07-02-2014 03:59 AM in reply to: vmorkunas
Active Member
hherrera
Re: seismic loading
07-11-2014 12:54 PM in reply to: Rafal.Gaweda
I noticed that when working with stories, walls between stories will default 100% to the upper story.  You can see that graphically when turning on the"Stories - legend by colors."  When reviewing the seismic weight calculation that robot does, it will place the entire seismic wall weight on the story that the wall belongs to.  We would like to see the seismic weight split by tributary height of the wall, between the upper and lower story.  Is there a way to have robot split the seismic self weight of the walls between stories?
