Hi
I am using windows 7 pro 64 bits with 64 bits (i7 processor).
When I try to take a screen capture using the PNG format of the Maps results for panels in the ARSA profeesional 2012 the legend of values is not displayed in the printout. This problem occurs only in the ARSA 2012 (it is OK in ARSA 2011).
Can you have a solution for the problem .
Thank you very much
Wassim.
We will check it.
But if you do not use opening map in new window the scale will be properly captured.
