Bonjour,
Suite à l'installation de Robot Structural Analisys professional 2014.
L'extension robot spreadsheet s'ouvre dans Excel, mais contrairement à la version 2013. Je n'ai aucun menu déroulant pour effectuer les calculs. La page s'ouvre et reste vierge.*Pouvez vous me dire ce que je peux faire pour remédier à ce problème.
Cordialement,
Solved by Artur.Kosakowski. Go to Solution.
Have you installed the design spreadsheets?
You need to download it from the Subscription site (the same as the previous version).
thank you for your answer,
my problem now, i'm a student and i want to try CBS pro but a dont have any active contract from autodesk. how can i do too have a CBS trial???
hi all
my spreadsheet caculation display error
I was setup Office 2003 and 2013 together
Thanks all
The error messge means that it WILL NOT run on your Excel.
Use office 2007 or 2010
Các messge lỗi có nghĩa là nó sẽ không chạy trên Excel của bạn.
Sử dụng Office 2007 hoặc 2010
i was setup Excel 2003 and 2013 together?
please guide me
Ask Microsoft
