Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
rc foundation
16 REPLIES 16
Message 1 of 17
1291 Views, 16 Replies
rc foundation
im trying to design the foundations, but i cant find out how. i got an exampel that says to select the analysis / design og RC Structure elements / RC foundation design, but it dosent work and i cant find the right buttons...
can you please help me?
16 REPLIES 16
Message 2 of 17
Artur.Kosakowski
Select the supported node and press the button indicated on the attached picture.
Artur Kosakowski
Message 3 of 17
in reply to: Artur.Kosakowski
but the screen is empty and all the results are empty?
Message 4 of 17
Artur.Kosakowski
Please find the foundation you imported from the model on the list in the Inspector and double click on it. This should invoke it on the screen. Then press the calculation button and switch on the results tab.
Artur Kosakowski
Message 5 of 17
i got a training manual that says that i shuld have a dimensions dialog box. where can i find it?
Message 6 of 17
Artur.Kosakowski
Check the foundation view tab please.
Artur Kosakowski
Message 7 of 17
i cant find a tab in that view, and now all i can see i black...
Message 8 of 17
Artur.Kosakowski
Please try to reduce the display acceleration as shown on the attached picture and restart Robot.
Artur Kosakowski
Message 9 of 17
its not helping... i attached a picture so you can see whats happing
Message 10 of 17
Artur.Kosakowski
Most likely you minimized the structure viewer. Try to maximize it or open the layouts from template.
Artur Kosakowski
Message 11 of 17
i sorry but i cant find it. its fine when your not trying to do the foundation but you do it all goes black...
Message 12 of 17
Artur.Kosakowski
I have checked that using the other option I proposed  (see the picture I attached to my previous answer) Tools > customize > open layouts from template you should be able to restore the default settings of the viewer. Could you try please?
Artur Kosakowski
Message 13 of 17
dimogrec
the solution proposed by Artur (on message 2) is fine if we want to design a footing under a column..
In case I have a structure (steel or RC) and I would like to design a raft foundation under the columns which is the proposed way to do it?
thanks in advance
Message 14 of 17
Artur.Kosakowski
in reply to: dimogrec
You can try to create a panel (shell) on elastic soil and use the RC Slab design module instead.
Artur Kosakowski
Message 15 of 17
dimogrec
thanks Artur.
Message 16 of 17
in case I want to calculate RC foundation just with the foundation module (not a part of a model in RSA, manually calculated forces), the module will calculate it will the specified soil beneath the foundation? In my case i have only the safe bearing pressure of soil (not specified what kind of soil it is), is there an option to do this, or have to find from literature for soils which bearing capacity correspond to which soil and select it from the RSA database?
Message 17 of 17
Rafal.Gaweda
qu ?
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-AC3744B2-B1FF-4EAB-BB55-2C5887C...
Rafal Gaweda
