Discussion Groups
Robot Structural Analysis
New Member
lis2984
Accepted Solution
raft foundation
645 Views, 4 Replies
01-10-2013 12:36 AM
Good morning
I m learning Robot 2011.
I m trying to model a raft foundation
would you please give me the steps?
Please use plain text.
Product Support
Rafal.Gaweda
Re: raft foundation
01-10-2013 12:41 AM in reply to: lis2984
ordinary plate but in thickness defintion add soil elasticity
Rafal Gaweda
New Member
lis2984
Re: raft foundation
01-15-2013 06:07 PM in reply to: Rafal.Gaweda
thxs!
Active Contributor
willjvizcaya
Re: raft foundation
04-22-2013 04:15 PM in reply to: lis2984
Hi, im also new with the slab foundation and elastic ground..
I have made this model for a slab foundation, i hate a ellastic coefficient of 25Ton/m3 but i dont think i defined correctly the planar Kz since soil pressure in the result maps goes above 180 T/m2 ( According to soil study Max 25Ton/m2).
1) Can you pls tell me how to correctly define Kz (it ask for a load above foundation) and Kz=0 when i do it this way.
2) is it ok to define a kz manually since i have the value.
3)How can i see the soil pressure correctly, the moment and shear diagrams?? i have seen it in other models but cant find the panel cut tool.
Thank you for ur help.
Regards
Product Support
Rafal.Gaweda
Re: raft foundation
04-25-2013 01:25 AM in reply to: willjvizcaya
I do not understand your model data. If you know kz = 25 T/m3 so why have you specified kz~3000 T/m3 ?
Take a look below sw of your slab is 1680 T and it gives pressure 34,46 T/m2 ; soil kz = 25 T/m3 means that if you have load of 25 T/m2 it will be displaced 1m. So in your case you get 1,34m displacement.
Yes
Results menu \ Panel Cuts
Rafal Gaweda
