At the sturm verification (static are ok , and modal finshed ) , the calculation stops and i have this message "Problème d'exéution" !
What is the cause of this, and how to correct the model in consequence.
Its top urgent.
thx
Solved by faisal.aaouatif. Go to Solution.
Please attach the model. Use Save as without results and compress to ZIP to reduce the size if it's too big.
after compressing the file , it still too large ( more than 6 MB)
what can i do
After moving the model to another station with more memory capacity ( C:/ ) , ive got no probleme !
thank you anyway
