I'm having trouble with regards to meshing, I keep on getting the "Inconsistent meshes around edges" error. Hope anyone could advice me on this matter.
Thanks!
Solved by Rafal.Gaweda. Go to Solution.
I did as mentioned above and some additional steps.
I got no more errors but 6 warnings, 2 of which say "Incoherent mesh on edges" and "Error - object meshing". I attached a file showing all the warnings. Any suggestions in correcting these?
Thank you very much!
I used WeTransfer because the file is larger than the 1.5MB limit. Here's the link: http://we.tl/vswbmCKOOu
Some panels have no meshes yet, those are the ones that cause incoherence. Thank you!
I wish you have paid more attention while creating model., esspecially sloped elements and elements connected to them.
Thanks for the advice, Rafal. Sorry about that, auto-snap was the culprit.
