When I try to calculate a RC column in the provided reinforcement menu, I get that error message and I can't understand what i'm doing wrong. I have manual combinations defined and they are correctly set as ULS or SLS...
Furthermore, RC beam calculation works like a charm.
What could be wrong?
Define relation in Code Combinations (you do not need to generate them).
If it is not the case please send us model.
I'm not sure I understood what you said, but if I did, then it didn't solve the problem.
I wanted to send the model but somehow it has 400mb in size, I just realized! This shouldn't be because the model is not that big, it's just a small house....
How can I shrink it?
Save file as a rtd file without results under new file name.
Then : http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
Thank you!
I managed to get it to 800KB.
Open file in repair mode
or
delete all combinations, set correct natures to simple loadcases, create combinations again.
Corrected file attached.
"Code combinations: Simple load cases have not been defined" in RC
@Rafal.Gaweda I am experiencing a similar problem when selecting a column from structure and attempting to generate reinforcement. I have no issues generating reinforcement for Beams/Slabs.
Any suggestions on how to fix the issue? " Code combinations: Simple load cases have not been defined"
Thank you in advance
