Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
punching capacity of slab without shear reinforcement
6 REPLIES 6
CKDDIZ
922 Views, 6 Replies
Verification problem 2 - punching capacity of slab without shear reinf. cant get the right results.
In verification problem 1 - everything was ok.
I tried to apply the forces in the node from a node with rigid links to column placement - get get the right results still.
Can u please help me what am I doing wrong?
6 REPLIES 6
Artur.Kosakowski
in reply to: CKDDIZ
You have different RC code used in your model. I'm attaching the modified file.
Artur Kosakowski
CKDDIZ
in reply to: CKDDIZ
Thank you,
if I understand correctly,
the model was OK, but the code was set to user.
For calculating shear resistance Finnish code SFS-En 1992-1-1 must be used?
Thanx again
Artur.Kosakowski
in reply to: CKDDIZ
the model was OK,
Correct
EN 1992-1-1:2004 AC:2008
You can use different code but in such case the slab punching capacity may be different that the one from the reference example which is calculated for SFS-EN 1992-1-1
Artur Kosakowski
Hi I downloaded the Robot model which Artur provided and tried to run it on my machine but I get a different punching shear result,  as shown below. It appears that the deadload from the slab (4mx4mx0.24x24.5 = 94kN) is being added to the 192kN point load. Why is the punching now calculated for 286kN? Is the rigid membrane still working correctly? I have attached the Robot model.
Jon_wardrop
in reply to: Jon_wardrop
I think my problem above may be an example of ROBOT seeming to remember previoulsy calculated values and when you think you have re-run the design, you haven't and ROBOT is just presenting the values it previously calculated!
Whenever I am trying to learn something new in ROBOT this becomes an annoying problem.  I find that to resolve it you need to play around with the model (i.e change some input, re-run the anlysis and then change the input back to original and then re-run).
Is there any way to "purge " previous results, so ROBOT stops showing old values as results?
Jon
Try to select save without results file type and give the file a new name.
BTW: Does the following complain sound familiar?  "I have calculated all my project and now I want to make small change to a tiny part of it but I don't want to lose my results that are not going to be influenced by this change" Smiley Wink
Artur Kosakowski
