Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
problem with alpha fron fig 6.11 fron ec 1993-1-8
17 REPLIES 17
Message 1 of 18
Vasile74
903 Views, 17 Replies
hello!
In eurocode ec 1993-1-8 on fig. 6.11 value of alpha is max 8 min 4.45.
when i checked the connection beam to column the leff,nc is 225.3631......
225,3631/22,9=9.84>>8
please check the values and give me a answer...
Thank you!! (forgive my English)
17 REPLIES 17
Message 2 of 18
Artur.Kosakowski
in reply to: Vasile74
Is the 5th row the one close to the stiffener or the internal one? I think that for the 5thnone you should use another formulas from the table you attached.
Artur Kosakowski
Message 3 of 18
Vasile74
 - for example, the second row in the figure above, the column flange, the effective length of time a program is 207.1506 and m = 22.9, so alpha is 9.045>>8,  (leff,nc=alphaxm).
 - Please mark the figure that the formula uses to turn two screws (for column flange onlly) in the given situation in figure
Message 4 of 18
Vasile74
in reply to: Artur.Kosakowski
I attached above values of calculation parameters required to determine the value of alpha
Thank you, and I appreciate that you answered
Message 5 of 18
Artur.Kosakowski
Could you attach rtd file with this connection please?
Artur Kosakowski
Message 6 of 18
Vasile74
Message 7 of 18
Vasile74
So where wrong interpretation results provided by the program?
Sorry for the insistence, but I need to know.
Thanks for understanding!
Message 8 of 18
Artur.Kosakowski
Currently Robot extrapolates the values of  alpha 'above' 8 and 'below' 4.5. I have asked the development team to investigate this situation. Thank you for reporting it.
Artur Kosakowski
Message 9 of 18
Vasile74
Thanks for the reply.
It would be a problem to the combination of steel poles with concrete foundation., But this I will post it in the coming days ....
Message 10 of 18
Vasile74
Back with a question...
It can disable analysis by C.B.E, for:
P100-2011 is the equivalent EN 1998 (in my country)
Thank you!
Message 11 of 18
Artur.Kosakowski
Let me answer this question after the release of Robot 2015 Smiley Happy
Artur Kosakowski
Message 12 of 18
Vasile74
Thank you for yor answer and i hope you wiil fix these problems.
Message 13 of 18
Artur.Kosakowski
Thank you!
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Connections-Column-base-design-concrete-rein...
Artur Kosakowski
Message 14 of 18
Vasile74
Smiley Happy
Message 15 of 18
Vasile74
thank you for reference..
Message 16 of 18
Thank you!
This verificaton can be switched off in Robot 2015
Artur Kosakowski
Message 17 of 18
Corrected in SP1 for Robot 2015.
Artur Kosakowski
Message 18 of 18
Vasile74
Thank you for your message.
