In RSAPro2013 for a RC Design with Provided Reinforcement, when the "Columns-Parameters for RC Elements" window appears the "Manual Combinations" option is grayed out (see attached picture). The program selects de "Simple Cases" option.
If I click the OK button a "Value out of limits" warning displays right after.
For the selected member the "Loads" window is empty.
If I run the calculations, a "Calculations Errors" window displays with the following message:
"Code combinations: Simple load cases have not been defined"
Why is RSAPro2013 not importing the defined combos into the RC Design Module?
Most likely you haven't defined any manual combinations.
The program selects de "Simple Cases" option.If I click the OK button a "Value out of limits" warning displays right after.
I need the rtd file to look at.
