Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
panels button
5 REPLIES 5
Jorgew09
311 Views, 5 Replies
panels button
I'm using robot structual analysis 2012, and cannot find the panels button. please help?
5 REPLIES 5
Artur.Kosakowski
in reply to: Jorgew09
Please make sure you selected the right structure type (e.g. shell rather than frame) using Geometry > Structure type.
Artur Kosakowski
Jorgew09
in reply to: Artur.Kosakowski
Still can't find it..
Artur.Kosakowski
The position of the button for the default Shell layout is indicated on the attached picture. You can also use the text commands.
Artur Kosakowski
Jorgew09
I have attached a print screen, and there is no panels button to see
Artur.Kosakowski
The layout is the frame one. Use Geometry > Structure type and select Solid and then do this once more and select Shell again.
Artur Kosakowski
