Fast Question!
Using the panel buttons, i can create a panel within the boudaries of 4 elements with similar edges.. but i need a hole in the middle where is the tube. if i try to create the panel (or opening). selecting the 2 inner elements. it says (boundaries cannot be defined).. soo How do i make a hole without dividing the external frames??.
Best Regards and Thx!
It should be enough to define a circular contour inside the panel to create an opening.
