I want to model a moving carriage on a mast, this carriage applies coupling moments on the mast legs. I assigned a vehicle with loads as couples in opposite direction.
when I applied the moving load, it is assigned in a plane perpendicular to the plane in interest. I tried to play with the Gamma angle in the Route parameters but it rotates the load only but not the plane of the vehicle as per attached file.
I want the moving load to move in +Z direction, the vehicle is in XZ plane and the loads are in Y direction (all axis in Global dirctions)
so to make this work to the current model, I need to rotate the whole vehicle about the Z axis counterclock wize by 90 degress.
Solved by Artur.Kosakowski. Go to Solution.
See the attached picture.
