Discussion Groups
Robot Structural Analysis
Valued Contributor
mgaafar
moving load direction
211 Views, 2 Replies
01-31-2013 09:54 AM
   I want to model a moving carriage on a mast, this carriage applies coupling moments on the mast legs. I assigned a vehicle with loads as couples in opposite direction.
when I applied the moving load, it is assigned in a plane perpendicular to the plane in interest. I tried to play with the Gamma angle in the Route parameters but it rotates the load only but not the plane of the vehicle as per attached  file.
I want the moving load to move in +Z direction, the vehicle is in XZ plane and the loads are in Y direction (all axis in Global dirctions)
so to make this work to the current model, I need to rotate the whole vehicle about the Z axis counterclock wize by 90 degress.
Please use plain text.
Product Support
Artur.Kosakowski
Re: moving load direction
02-01-2013 12:13 AM in reply to: mgaafar
See the attached picture.
Artur Kosakowski
Valued Contributor
mgaafar
02-01-2013 10:22 AM in reply to: Artur.Kosakowski
Thanks alot Artur
