I've got a model that it's running slowly, at least much slower that it used to. I checked the file and it's 166 Mb so I can't attach it here.
I suspect the reason might be that it's still saving results from the last analysis so the question is: is there a way to delete these results?
Thank you,
sanjuan100
use "save as", select *.rtd without results and change filename before saving
Thanks Rafal.
Still weighting 166Mb, which I think it's too much for what it is. what was the best way of sending big files over?
Thank you
Rafal,
after compressing to zip, the file only weights less than 1Mb. I have attached here.
Please have a look.
Many thanks again,
sanjuan100
Attached file after opening in repair mode.
Thanks Rafal, that has solved the problem. Running smoothly now.
sanjuan100
