Discussion Groups
Robot Structural Analysis
Valued Contributor
Accepted Solution
mesh density overload, some loaded panels not analysing
245 Views, 5 Replies
08-08-2012 01:27 AM
Morning All,
I'm having some curious problems with this building model:
Image 1- One of the front lift panels creates an overly dense FE mesh.
Image 2 - The stairs on the RHS (in red) is loaded but doesn't seem to be analysing.
Image 3 - When adding a roof slab above the edge beam highlighted in red, the front wall panel (in red) shows no load transfer.
I also have a "no material" warning that keeps popping up during verification which I can't get rid of.
Zipped RTD file to follow. This post only allows 3 attachments at 1 time.
Any expert advice on solving the above would be greatly appreciated!
Scott
Please use plain text.
Valued Contributor
Re: mesh density overload, some loaded panels not analysing
08-08-2012 01:28 AM in reply to: Opel5
rtd attachment regarding post above
*Expert Elite* | International Moderator
Romanich
08-08-2012 01:37 AM in reply to: Opel5
first of all run generation of computational model and after that verification.
Product Support
Artur.Kosakowski
08-08-2012 01:47 AM in reply to: Opel5
Your expert name is the detailed correction to structural axes and planes where they are not defined  (you may call it precision if you prefer)  :smileyhappy:
Artur Kosakowski
Valued Contributor
08-08-2012 02:27 AM in reply to: Artur.Kosakowski
Many Thanks!!! It's working great now :smileyhappy:
Out of interest, is there any Robot guide / PDF focussing on debugging any of the above errors? I don't want to be the pain in the arse on this forum coming back with similar errors when they crop up.
Product Support
Artur.Kosakowski
08-08-2012 03:13 AM in reply to: Opel5
Try to use the search box located at the top fright corer and type the key words such as e.g. incoherent mesh.
See also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tips-for-using-Search-in-the-Autodesk-Forums...
Artur Kosakowski
