con I print a memory technique?
Solved by Rafal.Gaweda. Go to Solution.
the structural projects, especially in dwellings, are usually accompanied by a technical report of the project that sets out the technical characteristics of the materials to be used, loads...
it is a technical report of sizing calculations and of components verification.
thanks
Thanks but are there another solution?
where the note is saved?
Steel Design note:
- Simplified - > printout preview is generated -> save it whereever you want
- Full -> temporary file :
then save it whereever you want or make screen capture to add it to Printout Composition
- Save Table adds it to Printout Composition
