i got a model where one of the bars are getting an error. its saying that "material is not defined for bar no 22". when im in the object inspector it has a material. whats wrong?
Solved by Artur.Kosakowski. Go to Solution.
Please open the bars table and switch to the Edit tab. Most likely the material assigned to bar 22 is N/A. Change it to the right one selected from the available list.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
i have tried that, but it stil dosent work. i cant see what the problem is
In fact there is no material assigned to panels (or panel thickness label to be exact). Please define a new thickness (make sure you entered the right thickness and selected the right material) and apply it to the panels.
