hi,
It is attached file, I don't understand!!
Why loads are not distributed well?
Solved by Rafal.Gaweda. Go to Solution.
Delete all inner claddings \ contours becasue claddings can not overlap. Leave one big outer claddings or 3 as shown below - loads defined by you will be left after deleting inner claddings.
In the area marked below in blue loads can not be distributed because there are no non-parrallel bars to direction X of this cladding
Artur.Kosakowski and Rafal.Gaweda
thank you very much for help!!!!
it is solved!
