Hello, support!
After I have run my calcs, when i'm trying to switch on my loads(for example live load) I see these values(see attached picture). This values looks like as dynamic or pseudostaic loads. Why I can't see normal values? I have never seen such strange values before. May be I switched on something in my model? Please, can you advise how to get normal(static) values of the loads.
Solved by Artur.Kosakowski. Go to Solution.
Assuming that you made load to mass conversion - try to modify the settings converting load cases to either selected modal analysis case or dynamic mass rather than the global one.
Thanks! it works.
Little bit strange. Before I always converted loads to global mass, and I didn't have such load representation. Anyway, thank you.
