Discussion Groups
Robot Structural Analysis
Valued Mentor
tony.ridley
Re: lifting the construction
04-23-2012 06:31 AM in reply to: mortel09
normally, just use the spreader on two sides, it will be stable for regular shaped geometry.
Please use plain text.
Valued Contributor
mortel09
04-23-2012 06:35 AM in reply to: tony.ridley
we are not supposed to use spreader bars, but we have added a support in one of the corner were we have cross checked RX, RY and RZ. This worked with the instabilty in node 52 :smileywink:
Rafacascudo
04-23-2012 02:42 PM in reply to: mortel09
Mortel09 ,No instabilities on your original model if you use the multi-threaded solver.
Valued Contributor
mortel09
04-24-2012 12:53 AM in reply to: Rafacascudo
the multi-threaded solver? I added a support in on of the corner so hold the rotation (RX, RY and RZ), will this be wrong to do?
Valued Mentor
tony.ridley
04-24-2012 01:38 AM in reply to: mortel09
My opinion is that if you have an instability in a model, using multi threaded to avoid it is un-conservative and not recommended.  The model should run fine on automatic before switching to multi thread.
Product Support
04-24-2012 01:55 AM in reply to: tony.ridley
Multithreaded solver may not report instabilities that's why it is recommended to find all model instabilities (esspecially of type 1 and 2) using different solvers.
Rafal Gaweda
Valued Contributor
mortel09
04-24-2012 02:02 AM in reply to: Rafal.Gaweda
Iam not sure what to do, I attached the file, when you hit calculations you get a warning of instability in node 52. What should i do?
Valued Mentor
tony.ridley
04-24-2012 02:08 AM in reply to: mortel09
it's type 3, so may just be large differernce in stiffness.
Valued Contributor
mortel09
04-24-2012 02:11 AM in reply to: tony.ridley
Okei, thanks alot guys. The both of you have been really helpfull. I appreciate your help.
Product Support
Artur.Kosakowski
04-24-2012 02:58 AM in reply to: mortel09
Please check the displacements and rotations for case 1 (self-weight) before ignoring the reported instability.
Artur Kosakowski
