Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
lifting the construction
93 REPLIES 93
Message 1 of 94
6288 Views, 93 Replies
How can i simulate that the construction is getting lifted in robot. The construction i have build is going to be lifted onto an oil rig. how do i simulate this in robot?
93 REPLIES 93
Message 21 of 94
Rafal.Gaweda
This was example how to properly rotate support.
As Rafacascudo said :  "No ,just Ux ,as long as you set the support local direction like I recommended"
Rafal Gaweda
Message 22 of 94
in reply to: Rafal.Gaweda
why exactly just ux?
Message 23 of 94
Rafacascudo
in reply to: tony.ridley
Hi Tony, If you have a small free height to lift the structure ,the angle the cable will do with the horizontal will be smaller and the horizontal forces can be very significant! For example if you have an 45 degrees angle(which is not rare) ,horizontal forces will be equal to the vertical force lifted on that point. Anyway , even if the angles are closer to 90 degrees, I believe this is the exact solution for the problem. Hard work?? IĀ“m pretty sure an user as well skilled as you can set these supports in less than 30 secs!! And it is a fun solution!! If you change the lifting point coordinates ,youĀ“ll will notice the 4 supports automatically pointing toward that single lift point/node. šŸ˜‰
Rafael Medeiros
Message 24 of 94
tony.ridley
in reply to: Rafacascudo
Agree with your thoughts.  However I'm lazy sometimes šŸ˜ž
Actually though, we normally add another member to the system, called a "spreader"  The additional beam takes a compressive force, and leaves the actual structure to be picked up with a vertical force only.
I can send you a picture if you're not sure what it is.
Tony
Message 25 of 94
i would like a picture plz Smiley Happy
Message 26 of 94
When i calculate the file after i have added the supports on each corner I get a warning of instability on node 52... see the attached file. Should i take this to consideration or is it nothing to worry about?
Message 27 of 94
tony.ridley
can you post the model?
Message 28 of 94
there
Message 29 of 94
tony.ridley
model attached
Message 30 of 94
Why should I only cross off on the UX, and not UY? I attached my file, could you see if it looks like iam simulating a lift?
Message 31 of 94
tony.ridley
normally, just use the spreader on two sides, it will be stable for regular shaped geometry.
Message 32 of 94
we are not supposed to use spreader bars, but we have added a support in one of the corner were we have cross checked RX, RY and RZ. This worked with the instabilty in node 52 šŸ˜‰
Message 33 of 94
Rafacascudo
Mortel09 ,No instabilities on your original model if you use the multi-threaded solver.
Rafael Medeiros
Message 34 of 94
the multi-threaded solver? I added a support in on of the corner so hold the rotation (RX, RY and RZ), will this be wrong to do?
Message 35 of 94
tony.ridley
My opinion is that if you have an instability in a model, using multi threaded to avoid it is un-conservative and not recommended.  The model should run fine on automatic before switching to multi thread.
Message 36 of 94
Rafal.Gaweda
Multithreaded solver may not report instabilities that's why it is recommended to find all model instabilities (esspecially of type 1 and 2) using different solvers.
Rafal Gaweda
Message 37 of 94
Iam not sure what to do, I attached the file, when you hit calculations you get a warning of instability in node 52. What should i do?
Message 38 of 94
tony.ridley
it's type 3, so may just be large differernce in stiffness.
Message 39 of 94
Okei, thanks alot guys. The both of you have been really helpfull. I appreciate your help.
Message 40 of 94
Artur.Kosakowski
Please check the displacements and rotations for case 1 (self-weight) before ignoring the reported instability.
Artur Kosakowski
