lifting the construction
93 REPLIES 93
Message 1 of 94
6278 Views, 93 Replies
How can i simulate that the construction is getting lifted in robot. The construction i have build is going to be lifted onto an oil rig. how do i simulate this in robot?
93 REPLIES 93
Message 2 of 94
tony.ridley
add pinned support at the lift point, remove usual supports.  add self weight multiplied by a dynamic allowance for lifting.
thats it!
tony
Message 3 of 94
Rafal.Gaweda
in reply to: tony.ridley
Kudos for you Tony 🙂
Rafal Gaweda
Message 4 of 94
I have done that now, and I have connected the cable from the four corners to the pinned support. but when i calculate I get several warnings about instability in nodes and other warnings. How can I solve this problem? After the calculation the ratio is extremly high....
Message 5 of 94
tony.ridley
no sorry, I didnt mean add cables and then a single pinned support.  I mean add 4 (or how many you need) pinned supports at the place WHERE THE CABLE IS GOING TO CONNECT.  you don't really need to model the cable, no?
Message 6 of 94
My construction is going to be lifted at 1 point, so i added a pinned support over center of gravity of the contruction and connected cables from it to the 4 corners... but that didnt work very well... so what you are saying is that i should add 4 supports over center of gravity and then i dont need to pull cables to the corners?
I dont need to calculate the wire no...
Message 7 of 94
tony.ridley
I would not add the support OVER the CG, rather add a support(s) to the BEAM itself at the point(s) where the cable will attach.  Looking at the reactions at each support will tell you if the structure will be stable when it's lifted.
Adding a single support for a structure with no rotational restraint can't ever be modelled..
Message 8 of 94
I have attached a pic of what I have done, is this what you mean I should do (supports.png)? I have also attached a pic of how the lift will look like in my mind (supports2.png). Will it calculate the same thing ?
Message 9 of 94
tony.ridley
Of course, the structure modelled in "supports2" can never work.
It can spin around the support with out ever stopping!
So no, it won't calculate the same thing.
Message 10 of 94
okei, but if i had added a support that only takes forces from x and y directions in each corner at the bottom of the construction, and made sure that the reactions in the support is very low, so that the construction would not spin, would that be a possible solution? and make the support in top only takes forces in z-direction
Message 11 of 94
tony.ridley
Perfect!  (well, most likely you will need a lateral support at at least 2 corners)
or spring supports..................
Message 12 of 94
Rafacascudo
That´s not true.Forces on the inclined cables will produce horizontal forces on your structure. I would set the supports on the exact direction of the cables.Doing that you won´t need to add any other supports. For creating the " tricky" support ,create a new one fixing de X direction , then click on " direction" and give the coordinates of the point where the 4 cables will join.Then assign this support to your 4 lifting points.Check if they´re on the exact same direction of your cables.
Rafael Medeiros
Message 13 of 94
in reply to: Rafacascudo
Should all of the "fixed directions" be checked? Like on the pic?
Message 14 of 94
Rafacascudo
No ,just Ux ,as long as you set the support local direction like I recommended
Rafael Medeiros
Message 15 of 94
okei, but dose it look like i have done that according to the piecture i attached?
Message 16 of 94
Rafacascudo
Yes ,but it looks like the support directions are wrong, probabbly due to the fact you assigned a fixed support for them all
Rafael Medeiros
Message 17 of 94
tony.ridley
Perhaps this is true, but your method seems like a lot of hard work for not much gain.  But each to their own Smiley Happy
Message 18 of 94
okei, ill try that 😉 thx
Message 19 of 94
Rafal.Gaweda
Rafal Gaweda
Message 20 of 94
so now iam suppose to check of UX, UY and UZ? and not only UX?
