layout RC Beams/Beam - definition
15 REPLIES 15
Message 1 of 16
Jorgew09
971 Views, 15 Replies
i can't find the  RC Beams/Beam - definition layout. can you please help me?
15 REPLIES 15
Message 2 of 16
Artur.Kosakowski
in reply to: Jorgew09
In Robot 2012 it is no longer available. It has been replaced by the common Provided reinforcement one. From there you can access the RC Design modules in the stand alone modes using the buttons displayed on the right hand side edge of the screen. If you want to import beam from the model it will be automatically transferred to the appropriate module after its selection and pressing the export button as shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 16
Jorgew09
in reply to: Artur.Kosakowski
thank you. but now i got a new problem. i cant find the button so i can calculate according to my standard. (the calculation option set window)
Message 4 of 16
Artur.Kosakowski
The design code should be set in Job Preferences. The Calculation option dialog is available under a button of from the top text command menu.
Artur Kosakowski
Message 5 of 16
Jorgew09
thanks!
nowi cant find the curves from the beam results...
Message 6 of 16
Artur.Kosakowski
I hope  that this option will show itself as well after you read my answer Smiley Happy
Artur Kosakowski
Message 7 of 16
Jorgew09
thank you Artur.
when im in the reinforcement layout theres nothing there. it says no selection. what have i done  wrong this time?
Message 8 of 16
Artur.Kosakowski
Try to select in the Inspector the beam (column etc.) you want to design.
Artur Kosakowski
Message 9 of 16
Jorgew09
this is what im getting. stil no modell
Message 10 of 16
Artur.Kosakowski
The window you refer to is to display properties of selected reinforcement bar(s). Most likely unless you closed it) the beam's view is hidden behind this enlarged dialog. You can close it as well as try to restore the default arrangement of the dialogs or just add the beam's view window.
Artur Kosakowski
Message 11 of 16
Jorgew09
in the member type definition vindu i cant see the "calculations for the moment in the direction(s)". where can i find it?
Message 12 of 16
Artur.Kosakowski
I'm sorry but I can hardly see any link between the member type definition and the RC Beam Design layout and therefore I'm not sure if I understand you correctly. Could you make a screen capture that illustrate this new issue please?
Artur Kosakowski
Message 13 of 16
Jorgew09
Message 14 of 16
Artur.Kosakowski
Is your model type a 2D Frame?
Artur Kosakowski
Message 15 of 16
Jorgew09
no, 3D
Message 16 of 16
Artur.Kosakowski
Send me the rtd file please.
Artur Kosakowski
