issue with supports not falling within mesh
5 REPLIES 5
robmirgga
485 Views, 5 Replies
Hi
I am hoping you might be able to work out why my supports arent recognised within mesh/plates?
Roberto
5 REPLIES 5
Rafal.Gaweda
in reply to: robmirgga
Change structure type back to shell and correct Z coordinates.
Z should be = 0 (esspecially before changintype onto PLate)
Z.jpgg structure
Rafal Gaweda
robmirgga
in reply to: Rafal.Gaweda
Rafal
The only table which I can visualise nodes on is the following:
Having changed panels to RC shell, should I be able to visualise the Z coordinate also? Is there another mode I should be visualising the nodes?
Roberto
Rafal.Gaweda
Movie: http://screencast.com/t/DAnUcpKIC6
Rafal Gaweda
robmirgga
Thank you very much for your help
Rafal.Gaweda
BTW correct also panel Z coordinate in case of remeshing model.
Rafal Gaweda
