Hi
I am hoping you might be able to work out why my supports arent recognised within mesh/plates?
Roberto
Solved by Rafal.Gaweda. Go to Solution.
Change structure type back to shell and correct Z coordinates.
Z should be = 0 (esspecially before changintype onto PLate)
g structure
Rafal
The only table which I can visualise nodes on is the following:
Having changed panels to RC shell, should I be able to visualise the Z coordinate also? Is there another mode I should be visualising the nodes?
Roberto
BTW correct also panel Z coordinate in case of remeshing model.
