Is 8GB RAM required for installing ARSA 2015? if yes , how can i upgrade 2014 to 2015 and i have only 4GB RAM ?
Best Regards
Solved by Rafal.Gaweda. Go to Solution.
Hi noradeen,
I have to suggest you to upgrade your RAM. Try to visit www.crucial.com, there is a scan system that check your PC and find the perfect solution for your RAM upgrade.
Greetings
Noradeen
My W7 system after starting eats 3,2 GB RAM itself and no user program is run so 4 GB RAM seems to be a little bit small amount.
Dear sir
I did what you said and i upgraded to 8 GB but no result .
Regards
BTW - system requirement is W7 SP1, you have W7 only.
Upgrade your windows system.
So, if i have 4 Gb, will it be possible to install Robot 2015? In Robot 2014 says 8Gb too.... (http://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/CloudH... i'm running it with 4Gb.
Will be possible to install but it is below minimum requirements so we do not guarantee how this will work and such version will be out of ADSK service.
MInd that for Robot 2015 you have to have SP1 for W7 installed. Only 64-bit OS are supported. XP is not supported.
