Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
instability type 3 RX direction
18 REPLIES 18
Message 1 of 19
7606 Views, 18 Replies
When I calculate my modell i get the following error: instability of type 3 in RX direction
I have looked at the node but everything seems to be correct. I the releases box I have tried to tick off RX, but that did not help.
18 REPLIES 18
Message 2 of 19
Rafal.Gaweda
Open calculatin Report , find there Max min values on stiffeness matrix diagonal and write here these two values.
Rafal Gaweda
Message 3 of 19
in reply to: Rafal.Gaweda
Min/Max after decomposition:    7,463808e+006         6,847539e+019
precision: 1
Message 4 of 19
Rafal.Gaweda
if the difference between these values is greater than 1e11 \ 1e12 program reports instability number 3.
It is related to big differences in stiffenes of elements for example very short elements exist in model = some inaccuracies.
You can check it this way: on dummy model select everything, make intersection, then open Bars table on View tab. Find shortests bars. Then locate nodes \ places on original model and correct location of nodes.
If it is not the case. Send me model. You already know how.
Rafal Gaweda
Message 5 of 19
I don't understand how to do what you told me to do
Message 6 of 19
I'm sending the file:)
Message 7 of 19
Rafal.Gaweda
Example below
If not - send me the file.
Rafal Gaweda
Message 8 of 19
Rafal.Gaweda
Inacurracies in your model:
Rafal Gaweda
Message 9 of 19
please find attached 2 files.
https://dl.dropboxusercontent.com/u/79282449/AUVENT_V2.zip
the first, AUVENT_V2, is calculated without sismic load and is free of instability.
the second, AUVENT_V2_SISMIQUE, contains sismic loads and shows instability.
Calculation report :
Elém. diagon. de la matrice de rigidité
                Min/Max après décomposition:    4.067231e+002     2.066486e+015
     Précision:    2
Shortest calculaltion element : 0.16 m -> I think it's not too short
- Why?
- How be sure than we can ignore this instability (after checking node displacements, shorts elements)?
- Is it possible to highlight calculation node?
thanks
benoît
Message 10 of 19
Rafal.Gaweda
I do not think so :
Rafal Gaweda
Message 11 of 19
Rafal.Gaweda
Ignore it. Related to solver tolerances.
To check - use Skyline solver -> no instability.
Rafal Gaweda
Message 12 of 19
For me, "AUVENT_V2" has no instability (with automatic solver). I can't make a snapshot since there's no message 😉
For "AUVENT_V2_SISMIQUE", only multithread method gives no instability.
-> How is it possible to justify that the instability can be ignored?
-> How is it possible to highlight the calculation node wich is going wrong?
thanks
benoît
Message 13 of 19
Rafal.Gaweda
In this case - change solver onto Skyline ;
Create new case apply nodal load on direction given in warning message, after caclulations check displacement and rotations in this node
In general this way starting from v 2014:
(In your model there is nothing wrong in this node - see above)
Rafal Gaweda
Message 14 of 19
-> what must be the result? no displacement or rotation?
Benoît
Message 15 of 19
Rafal.Gaweda
Huge displacement or rotation => problem in this node
Rafal Gaweda
Message 16 of 19
Had the Same Error, But on verification it doesn't appear.Smiley Indifferent
See attached Screenies
Message 17 of 19
Rafal.Gaweda
File please
Rafal Gaweda
Message 18 of 19
EY23
Dear Rafal,
I have the same issue here. can you check my model please?
Message 19 of 19
Rafal.Gaweda
in reply to: EY23
Move node 88 onto 89
Rafal Gaweda
