Discussion Groups
Robot Structural Analysis
New Member
GPiccinetti
Accepted Solution
instability of type 2
527 Views, 1 Replies
12-05-2012 02:18 AM
robot detect an instability of tpe 2 in the node 128 (directione RZ). There aren't any  mechanical instability of the structure so i don't know how to fix the problem. On-line guide doesnt'help me.  How can i solve the problem?
Thanks in advance
Please use plain text.
Product Support
Artur.Kosakowski
Re: instability of type 2
12-05-2012 02:49 AM in reply to: GPiccinetti
Definition of releases. I would block RX in the definitions of releases, check the results obtained for such model and address MX locally if needed. If you also block RZ in the definitions of the supports you will solve the instability issue.
Artur Kosakowski
