Discussion Groups
Robot Structural Analysis
New Member
Accepted Solution
instability (of type 1) at node RZ direction
696 Views, 2 Replies
11-04-2012 05:46 AM
I've been playing arround with robot for a school project, trying to analyse a simplified structural model I've made of the Downland gridshell building located in Sussex.
I'm getting instabillity warnings, and useless results when I press calculate, and being a beginner I've struggled to figure out what the problem might be.
Changing the releases and supports, didn't do anything, so I'm running out of good ideas. I hope some of you guys may be able to help?
Kind regards, Jacob
Please use plain text.
Product Support
Re: instability (of type 1) at node RZ direction
11-05-2012 12:41 AM in reply to: jhilme08
Caused by releases.
You have applied releases to all bars making all of them truss bars so the whole model is unstable.
Correct or remove releases.
Rafal Gaweda
New Member
11-05-2012 08:28 AM in reply to: Rafal.Gaweda
Thank you.
It solved the problem even though I thought I've allready tried it.
