In verification - i get error as "inchorent mesh on egde, no metarial" and I can not calculate. I tryed every solution which is written here..
(http://forums.autodesk.com/t5/Autodesk-Robot-Structural/model-error/m-p/3464494/highlight/true#M4935,
Could you please help me, what should I do?
Solved by Artur.Kosakowski. Go to Solution.
Hint 1: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Meshing-into-robots-2012/m-p/3310651
screen shot in message 4 - !!!!! settings of greyed out fields are also important that's why they are market in red !!!!!
thanks for your quick response
how can I unmarked "Automatic emitters", i don't know... that's why I left them.
Select the Delaunay method and then switch them off. When done select the Coons method.
hi,
I get same problem again : ((
i tried every solution (mesh option, iterative constrains etc.)
also i tried to solve manually
but again, warning "inchorent mesh" and i can not calculate ....
could you pls help me,
i have no idea why i am getting this error..
thanks
Remesh some walls to obtain coherent mesh.
File here: https://www.filemail.com/d/qfkxtfbiizmopff
How do I do this from API? Coons and Delaunay I know how to control, but Kinematic constraints?
