How can i draw 2 beams on one col 30*100 cm2
on it at 10 cm from edge and the other is 80 from the same edge ?
the col is modeled as one line with one node at top ?
Solved by Artur.Kosakowski. Go to Solution.
Try to draw them where they are in reality and connect them with rigid links.
