Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
i've problem with elastic soil!
3 REPLIES 3
deezed
337 Views, 3 Replies
hi,i've problem with banding moment,it should be like this:
i attached the file ,could anyone help me please!
deezed
3 REPLIES 3
Artur.Kosakowski
in reply to: deezed
The shape of diagram depends on the stiffness of both soil and the beam. If you reduce them you should get the diagram as on the picture you attached. In addition I think that you may want to allow for the uplift in the soil definition and remove the vertical spring from the nodal supports (see the attached model with such changes).
See also: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Spring-support-results/td-p/4883686
Artur Kosakowski
deezed
in reply to: Artur.Kosakowski
hi;i do not understand what did you do with the nodal supports!can you explain it with picture or video if is possible!
deezed
Artur.Kosakowski
in reply to: deezed
I set KZ as 0 as you have already  defined KZ in the elastic soil under bars.
Artur Kosakowski
