Hi, I think I found a bug in RSA when showing the hydrostatic load by pressing "load symbol" icon, the load direction is shown opposite to that assign (opposite to the local axis of the panel. the load direction shows properly when pressing "load value description" icon with the "load symbol" icon. This problem usually appears after running the model.
http://www.screencast.com/t/UKiKto1E
Solved by Rafal.Gaweda. Go to Solution.
Pretty sure there is something about this on the forums already and that it has been corrected by one of the later Service Packs.
Might be worth checking you are up to date.
Richard
