hello
i am looking to design a curved truss of 80 meter span . is there anyway i can get model coordinates for a general design.
thank you
Solved by Rafal.Gaweda. Go to Solution.
how can i create something to look similar to this ? should i use the tool u have shown me or something different?
see attached
can you show me roughly how i do this ? i am unsure as to how create a model , is there anyway i can get a hold of an example. possibly coordinates.
thank you
i have a attached a diagram of the problem in question can anyone help
thank you
gordon
when designing a truss how myust i model the releases of the inner members of the truss?
Generaly a truss roof is modeled with pinned supports (not fixed as your picture). But if you add bar releases to all members (including the bar extremes ending to a support) you can leave it with fised supports
What do you mean by "How can I make this 3d so essential two of the above makes one truss?" . Is it a 2d structure? if so go to "Geometry->Structure type" and choose 3d frame or 3d truss...
thabnks for the help.
i was wandering is there an option to get the price of the structure designed in robot? thanks
