Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
how to define Half-closed channel
3 REPLIES 3
447 Views, 3 Replies
hi,
anyone have any idea how to define or select from default material Half-closed channel?
please, i need assist in this matter.
thanks.
Tags (1)
3 REPLIES 3
tony.ridley
Define or select material section?
in reply to: tony.ridley
 define the new section which is half-closed channel. because in the user's guideline in http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-37C90ACA-0068-46B0-9CE2-76DEF8EED29-1630.htm there's a section half-closed channel.
Artur.Kosakowski
Assuming that the steel design code formulas for solid channel and half-closed channels are the same (which I think is true) just assign your section a channel symbol available from the list of sections in the save to the user database dialog.
Artur Kosakowski
