Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
how to create an axis arch in robot
9 REPLIES 9
Message 1 of 10
huyxp
1735 Views, 9 Replies
i don't know create a axis arch in robot?
please tutorial for me step by step create an axis arch in robot as show iamge below
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
in reply to: huyxp
See message 4 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Curve-fitting-panels-amp-auto-update-of-pane...
Mark the create bars check box if needed.
Artur Kosakowski
Message 3 of 10
huyxp
in reply to: huyxp
tks you
I want draw a beam arch or simple bar arch ???
Message 4 of 10
Artur.Kosakowski
in reply to: huyxp
The bar type is the set of the parameters you want to use in the design modules of Robot. It is irrelevant for static calculations of the model itself.
Artur Kosakowski
Message 5 of 10
huyxp
in reply to: Artur.Kosakowski
hi tks you very much
can you tutorial as movie??
Message 6 of 10
Artur.Kosakowski
in reply to: huyxp
Like clicking on 3 points that define an arch? Smiley Happy
Artur Kosakowski
Message 7 of 10
huyxp
in reply to: huyxp
how to create truss arch as iamge below?
Message 8 of 10
Artur.Kosakowski
in reply to: huyxp
Replace the top and bottom arch with lines from one bar intersection to another. Save the file as a dxf. Open it in Robot.
Artur Kosakowski
Message 9 of 10
huyxp
in reply to: huyxp
thank You very much
But I had a problem as image below
Message 10 of 10
Artur.Kosakowski
in reply to: huyxp
Try to replace the arches in AutoCAD with lines from node to node.
Artur Kosakowski
