Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
hi incoherent mesh no matter what options specified
8 REPLIES 8
Message 1 of 9
Tmlk89
670 Views, 8 Replies
Hi there
i've had a great trouble with the error incoherent mesh on edges and i really need this to work
any  ideas guys ?!??!
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
in reply to: Tmlk89
I would focus on the way the analytical model has been created in Revit and correct it either in Revit or Robot before trying to mesh it.
Artur Kosakowski
Message 3 of 9
Tmlk89
in reply to: Tmlk89
First
thanks alot for your rply and feeback
i 've modeled the first two levels which are the parking level and the ground level correctly with least incoherent mesh troubles
as a matter of fact im calculating the reinforcement for them this instance
as a student im open to any kind of knowledge or info.
but i've tried to correct both the physical and the analytical model many times without any luck
and my professor wants me to use delaunay mesh method with element size of 0.5 m
any more help would be greatly appreciated
Message 4 of 9
Tmlk89
in reply to: Tmlk89
if possible how can i make robot  to ASD display The Diameter of the reinforcement  in mm not in numbers
#3 or any other number
Message 5 of 9
Artur.Kosakowski
in reply to: Tmlk89
This depends on the selected design code/reinforcement bar database (US vs. e.g. EC)
Artur Kosakowski
Message 6 of 9
Tmlk89
in reply to: Artur.Kosakowski
Thx alot
so about the meshing
i should just select and drag the incoherence point to another and calculate right ?
Message 7 of 9
Artur.Kosakowski
in reply to: Tmlk89
You may find these posts useful:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Revit-to-Robot-link-why-are-rigid-links-crea...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/m-p/3334637
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Calculations-not-completed-objects-not-in-sa...
Artur Kosakowski
Message 8 of 9
Tmlk89
hey artur
i've been rtrying to fix the meshing manually since yesterday and it's pretty crutial i do it in the next 2-5hours
can u help me remesh my model or send me the meshed model please
i know u're a busy man and it's too much to ask
but is there anyway u could do that
im still a newbie to autodesk awesome products
Message 9 of 9
Tmlk89
in reply to: Tmlk89
im getting the warning distorted element and i cant get rid of the incoherence error
