Hi there
i've had a great trouble with the error incoherent mesh on edges and i really need this to work
any ideas guys ?!??!
Solved by Artur.Kosakowski. Go to Solution.
I would focus on the way the analytical model has been created in Revit and correct it either in Revit or Robot before trying to mesh it.
First
thanks alot for your rply and feeback
i 've modeled the first two levels which are the parking level and the ground level correctly with least incoherent mesh troubles
as a matter of fact im calculating the reinforcement for them this instance
as a student im open to any kind of knowledge or info.
but i've tried to correct both the physical and the analytical model many times without any luck
and my professor wants me to use delaunay mesh method with element size of 0.5 m
any more help would be greatly appreciated
if possible how can i make robot to ASD display The Diameter of the reinforcement in mm not in numbers
#3 or any other number
This depends on the selected design code/reinforcement bar database (US vs. e.g. EC)
You may find these posts useful:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/m-p/3334637
