gravity center of structure
6 REPLIES 6
jo2ny
730 Views, 6 Replies
Hi all,
I'm testing the otput of the center of gravity and total mass of a structure.
The model is simple, i attached it.
My question is: how are the COG and mass calculated because running a "hand made" verification the results are not the same:
Robot reactions: 1 Sw = 0.79 kN = 81 kg
                            2 Ov = 20 kN = 2039 kg
Sum = 20.79 kN = 2120 kg
Robot ->
Structure gravity center coordinates:
X =      1.000 (m)
Y =      1.000 (m)
Z =      0.000 (m)
Central moments of inertia of a structure:
Ix =     43.241 (kg*m2)
Iy =     48.648 (kg*m2)
Iz =     92.010 (kg*m2)
Mass =     81.066 (kg) OK
Coordinates of structure centroid with static global masses considered:
X =      1.000 (m)
Y =      1.463 (m)
Z =      0.000 (m)
Central moments of inertia of a structure with static global masses considered:
Ix =    639.287 (kg*m2)
Iy =   1210.087 (kg*m2)
Iz =   1849.495 (kg*m2)
Mass =   2201.565 (kg) Why not 2120 kg = 20.79 kN?
Obvious a further calculation of the coordinates of the COG wil not have the same result (X=1.00m / Y=1.463m / Z=0.00m)
Thank you in advance!
I'm running ARSA Pro 2012
Tags (2)
6 REPLIES 6
Rafal.Gaweda
in reply to: jo2ny
The cause:
Rafal Gaweda
jo2ny
in reply to: Rafal.Gaweda
You are suggesting, that the self weight is taken into consideration twice? 2039+81+81 = 2202 kg ?
That means that I shoud remove self weight from load to mass conversion to get the corect COG?
If so, what about a model with modal analysis and seismic cases, in which i would normaly include Sw into load to mass conv. + disregard density?
Rafal.Gaweda
in reply to: jo2ny
Your choice, but remember not to double sw for masses unless you really want this.
Rafal Gaweda
jo2ny
Ok, one more time to be sure i got it right:
Load to mass conv. of Sw and Ov + diregard density is the same with load to mass of Ov without disregard density thicked?
Rafal.Gaweda
in reply to: jo2ny
Yes.
Rafal Gaweda
jo2ny
Thank you!
