generating Load cases by API
8 REPLIES 8
Message 1 of 9
Leader_Mohamed
1242 Views, 8 Replies
HI everyone,
I'm tyring to generate Load cases and Load Combinaions using API and it's the first time to make an API so here's some questions
 1- how to assign the Self Weight to the first load case that I define ?
 2- how to get the nubmer of previous load cases to delete them then generate new ones ?
 3-how to define a Limit state combination like 1.12DL+1.28LL+1.28W ?
        Dim robot As New RobotApplication
        robot.Project.Structure.Cases.Delete(1)
        robot.Project.Structure.Cases.Delete(2)
        robot.Project.Structure.Cases.Delete(3)
        robot.Project.Structure.Cases.Delete(4)
        robot.Project.Structure.Cases.Delete(5)
        robot.Project.Structure.Cases.Delete(6)
        robot.Project.Structure.Cases.Delete(7)
        robot.Project.Structure.Cases.Delete(8)
        robot.Project.Structure.Cases.Delete(9)
        robot.Project.Structure.Cases.Delete(10)
        Dim caseSW As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(1, "Self Wei ht", IRobotCaseNature.I_CN_PERMANENT, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim casefloorcover As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(2, "floor cover", IRobotCaseNature.I_CN_PERMANENT, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim caseWallLoad As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(3, "Wall Loads", IRobotCaseNature.I_CN_PERMANENT, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim caseLiveLoad As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(4, "Live Load", IRobotCaseNature.I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim CaseWxpos As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(5, "wind X +", IRobotCaseNature.I_CN_WIND, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim caseWxNeg As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(6, "wind X -", IRobotCaseNature.I_CN_WIND, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim caseWYpos As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(7, "wind Y +", IRobotCaseNature.I_CN_WIND, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
        Dim caseWYneg As RobotSimpleCase = robot.Project.Structure.Cases.CreateSimple(8, "wind Y-", IRobotCaseNature.I_CN_WIND, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
 thanks in advance.
8 REPLIES 8
Message 2 of 9
another question
is IRobotCaseNature.I_CN_EXPLOATATION means Live Load case ?
Message 3 of 9
Yes.
Rafal Gaweda
Message 4 of 9
Message 5 of 9
Example:
Dim RecordNew As RobotLoadRecord
                Set RecordNew = caseSW.Records.Create(I_LRT_DEAD)
                RecordNew.SetValue I_DRV_COEFF, 1.0
                RecordNew.SetValue I_DRV_ENTIRE_STRUCTURE, 1
                RecordNew.SetValue I_DRV_Z, -1
Rafal Gaweda
Message 6 of 9
Dim Rselection As RobotSelection
Set Rselection = robot.Project.Structure.Selections.CreatePredefined(I_PS_CASE_SIMPLE_CASES)
robot.Project.Structure.Cases.DeleteMany Rselection
Rafal Gaweda
Message 7 of 9
teixeiranh
in reply to: Rafal.Gaweda
Hi Rafa! How do I delete all load records from a sort of load cases, keeping of course the load cases free of any record (via API)?
For example, I want to delete all load records from cases 2 to 5.
Thank you!
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 8 of 9
1234eddie
in reply to: teixeiranh
Message 9 of 9
Rafal.Gaweda
Hi @teixeiranh
Either You have to delete records in loop or delete load cases and create them again.
Rafal Gaweda
