Hi
i would like to model a pipe with a axial release, function of he internal pressure.
How can I create a bar release definitiion with a friction property?
Solved by Rafal.Gaweda. Go to Solution.
I've tried to model a friction property (see attach) but the results are not what I expected.
I've fixed an upper value of force. In my mind, when the force due to thermal conditions is higher of that limit, the release have to release completely ux and the bar with a fx force = 0.
Maybe this way:
File with such function attached
Ok, it works but I don't understand the meaning of the use of "case component". Is a time history analysis like?
when i do the analysis with my RSA I have this error message (see attach).
I have activated saving results for each iteration in nonlinear settings to see how it works
Run buckling calculations and check buckling coefficients.
