Discussion Groups
Robot Structural Analysis
Active Member
amirdj.gc
foundation design
270 Views, 5 Replies
11-09-2012 02:27 AM
Hello, can i design the foundation with only the stress presiometric allowable value because i dont have all the soil caractristcs.
so i have to delet the soil type (clay , sand ....) but i cant do that.
Please use plain text.
Product Support
Artur.Kosakowski
Re: foundation design
11-09-2012 02:39 AM in reply to: amirdj.gc
Type the value of the allowable stress rather than use the analytical method.
Artur Kosakowski
Active Member
amirdj.gc
11-09-2012 03:24 AM in reply to: Artur.Kosakowski
thank you for the explanation but when i do these steps i can see in the foundation note that the soil type is included as you can see in the picture,
Product Support
Artur.Kosakowski
11-09-2012 03:39 AM in reply to: amirdj.gc
For the settings as on my picture the marked value will be used regardless of the soil profile you have defined in the Soils dialog.
Artur Kosakowski
Active Member
amirdj.gc
11-09-2012 04:16 AM in reply to: Artur.Kosakowski
i know that the value of the stress pressiometric is used but when i change the soil type the results change, why that
Product Support
Artur.Kosakowski
11-09-2012 05:52 AM in reply to: amirdj.gc
I'm not sure if I understand you correctly. The stress limit in the soil should not change but the load due to the change of soil weight can.
Artur Kosakowski
