As far as I can see the value of required reinforcement area in each of surface element is 0. Please check if by accident you created support in every node of the structure (e.g. applying a planar support to the panel) having minimal reinforcement switched off in the reinforcement type assigned to the panel. Otherwise I will need the rtd file to check the model.
I'm not saing that I can read in somebody's mind but ...
