Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
factor of safety for shear in RC-Columns
4 REPLIES 4
Refaat
422 Views, 4 Replies
Dear Sirs
Could I get advice for the following inquiries :
- Why does the safety factor for shear in columns is very high when I use only external stirrup ?
- Why does the safety factor for shear in column with internal stirrup is less than that of the column without internal stirrup ?
Please , Could you take a look for attached captures and file.
Note : If you use any capture for explanation . Kindly send it as attached.
Thanks in advance
Refaat
4 REPLIES 4
Artur.Kosakowski
in reply to: Refaat
I can't see such problem. Could you send me the file where you have the 'middle' stirrups defined?
Artur Kosakowski
Refaat
in reply to: Artur.Kosakowski
Dear Artur
Attached is the required file . could you take a look to it?
Thanks in advance
Refaat
Artur.Kosakowski
in reply to: Refaat
What was the way you generated this reinforcement distribution in the column?
Artur Kosakowski
Refaat
Dear Artur
I used "Typical Reinforcement" option
Refaat
