Hello, my project is a RC structure building. I am working in "Building Design" in robot. My problem is that when i choose the "pinned-pinned" type of release for all my columns; during the analysis it keeps giving me warnings about instabilities(type 2) at some nodes , and the calculations freeze when it reaches the case "Modal"(Dynamic analysis: seismic). But when i ran my model without any type of release, the calculations went fine and without any warnings or errors so i know that the issue is not with the structure. And i need the "pinned-pinned" release for my columns. I don't understand what i'm doing wrong so if you could help me, i would really appreciate it. Thank you !
Solved by Artur.Kosakowski. Go to Solution.
Check if you have any restrain for horizontal movements of the building. Perhaps you should define some bracings?
Thank you for your answer. Bracing was the solution. Thanks for the help 🙂
