Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 21
GabrieleNovembri1027
1155 Views, 20 Replies
error
Hi all,
I tried to install RSA2012 on a desktop computer, and when I launch the program, I always get this error:
Any suggestions?
20 REPLIES 20
Message 2 of 21
I got the same error after my 1st installation, this message should disappears after rebooting.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 21
Hello Jad,
I have the same problem all times I start Robot PRO 2012.....we already need a SP???
Bye
Roberto
Message 4 of 21
After rebooting and filling the projects side, this error will disappear
Please confirm us that works or not, thanks.
Jad DELLEL
Message 5 of 21
Hello jad,
unfortunatly even with 4 project on that side I have this error starting robot, after clicking twice on "continua" I can start
Bye
Roberto
Message 6 of 21
A similar effect was observed on Win XP 32bit machines with memory card readers .
Problem could be avoided changing drive letters for the card reader using Disk Management. We have changed from E, F, G, H to K, L, M, N
Problem was not observed on the identical machine, where Win XP 32bit was replaced by Win XP 64bit
Similar problem is discussed there:
http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
Jad DELLEL
Message 7 of 21
Hello jad,
if you consider that I'm using Robot on WIN 7 64bit I think I will continue to click twice on "Continua" button....waiting for a welcome SP
Bye
Roberto
Message 8 of 21
Have you tried the solution up?
Jad DELLEL
Message 9 of 21
in reply to: GabrieleNovembri1027
Morning all,
I have just installed RSA2013, when I run it I also get the harddisk2/DR2 error message. After clicking continue I get through to the project screen, but when I try to create a new project the software stops working and the Autodesk error report box pops up and the software closes after I have clicked to send the report.
Any suggestions would be appreciated.
Pete
Message 10 of 21
Rafal.Gaweda
Have you tried that:?
Rafal Gaweda
Message 11 of 21
in reply to: Rafal.Gaweda
Have changed the drive names but I still can't progress past the project screen
Message 13 of 21
Rafal.Gaweda
Have you seen crash report window where you can specify e-mail address and report crash? If so please register crash specifying your e-mail address.
Try this: open RC design, if there is no crash please go to Preferences and change OpenGL acceleration, then restart robot and check.
Rafal Gaweda
Message 14 of 21
Error report registered and SP2 installed. Still not able progress any further, when accessing a project type it tries to load the model space but then stalls and error report pops up.
Message 15 of 21
Rafal.Gaweda
THx, we are checking it.
The same if you select RC Element stucture type?
Rafal Gaweda
Message 16 of 21
Rafal.Gaweda
The crash is generated by ATI graphics card driver. PLease update your graphics card driver to the newest one.
Rafal Gaweda
Message 17 of 21
Thought I should clarify so that you don't think im trigger happy, I logged two reports, pre and post SP2 install, not sure if that helps.
Yes tried going through RC element structure same result, sorry meant to stipulate.
Thanks for looking into it.
Message 18 of 21
Rafal.Gaweda
Analyzing them we found that crash is caused by ATI graphics card driver.
Rafal Gaweda
Message 19 of 21
Much appreciated Rafal, with get the card updated.
Message 20 of 21
Rafal.Gaweda
Peter,
Try this structure type, Tools \ Preferences,  then turn off OpenGL in Robot.
Rafal Gaweda
