Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
elevated conical tank:seismic and hydrodynamic loads calculation
35 REPLIES 35
Message 1 of 36
REDO10
2162 Views, 35 Replies
I'm looking for an exemple of modeling seismic and hydrodynamic loads for an elevated conical tank!
I tried modeling it, but when I define masses, the following message appears " load by hydrostatic pressure can not be converted into masses. delete the hydrostatic pressure of the case converted"
I can't attach my file bellow, because it's too large (114 Mo).
thanks.
35 REPLIES 35
Message 21 of 36
Rafal.Gaweda
in reply to: REDO10
I calculated the impulsive force and mass induced by the method of HOUZNER and got the following results:                 Fi (impulsive force) = -4562 KN  and  Mi (impulsive mass ) = 1028 t.
how can I enter these values?
What is that?
1- I used Houzner's method to calculate hydrodynamic forces generated when seisme happen and I obtained the results above, I want now assign the mass calculated (Mi=1028t) to my model, so pls do that for me (I attached my file below)
We found this article : http://authors.library.caltech.edu/26535/1/Housner_gw_1954.pdf
Our understanding is that you have to calculate mass for each "strip" and apply them on model. You can do it by connecting liquid strip center of gravity (each) with applied mass to walls - in robot by rigid links, thus this approach will make model not real - too stiff. You have to distribute this mass (for each strip) to wall nodes of this strip to make it more real.
If our understaning is not correct please explain.
Rafal Gaweda
Message 22 of 36
REDO10
in reply to: Rafal.Gaweda
Hi Rafal,
Thx for your reply
and for enter mass value that I calculated as shown above, can you do that for me pls or make a demonstration to enter correct value?
Message 23 of 36
Rafal.Gaweda
in reply to: REDO10
My assuptions = example
The strip (in red) - "3 rows of nodes":
36 - number of nodes of circle
Mi=1028 (strip mass)
mass applied to any node from yellow set =  mass applied to any node from green set = 1028 *0.25 / 36 =257
mass applied to any node from blue set =  1028 *0.5 / 36 = 514
these masses should act at least in XY directions or XYZ , apply them to Modal case
or as forces in masse_eau case (I guess) and then convert this case to masses
Rafal Gaweda
Message 24 of 36
REDO10
why you chose the tower in your example, the mass should be applied to the tank!
look at my capture below, my modeling is correct according to your demonstration?
thx.
Message 25 of 36
Rafal.Gaweda
in reply to: REDO10
For the simplicity.
Yes.
Rafal Gaweda
Message 26 of 36
REDO10
I think it is not correct, because I noticed that the forces directed along the Y axis are not diametrically opposed!?...They must be oriented along the local axis! Smiley Frustrated
Message 27 of 36
REDO10
in reply to: REDO10
Pls Rafal, enter these values in my model, I will be very grateful
thnks
Message 28 of 36
REDO10
in reply to: REDO10
normally the mass must be applied along the axis 3  of noueds, but how to do that?
Message 29 of 36
REDO10
in reply to: REDO10
my modelization is correct now?
I used uniforme planar load on contour to define load!
thx.
Message 30 of 36
REDO10
1-Why u've chosen 3 rows of noeds? why not 4 or 5...or simply 1 ? and how can I know the exact level for applying masses?
2- If I chosen to add masses in modal case, should I select more rows too or apply them simply in 1 row ?
3-  I've enter the values such as you indicated in "masse_eau" case then convert them to masses, but when I launched calculation, this error message appears
so I've applyed them in modal case, and I obtained the results below, which seem to me wrong, especially the sum of the masses in the modal analysis and the moment along the Y axis and the shear along the X axis in combination case "G+Q+E"
thx
so
Message 31 of 36
Rafal.Gaweda
in reply to: REDO10
for simplicity, as an example
You should know how you calcaulated masses, from which range.
See above
File please.
Rafal Gaweda
Message 32 of 36
REDO10
Hi Rafal,
See above
File please.
My file is attached to my post N°17 in page 2 (elevated_tank_1000)
Thx.
Message 33 of 36
Rafal.Gaweda
in reply to: REDO10
My results for model from post 17
Rafal Gaweda
Message 34 of 36
REDO10
Hi Rafal,
I forgot to enter the mass in the old file you calculate, so pls check this new file where I get error 5000,
question:
should I check disregrad density in modal option?
comment my results pls!
Message 35 of 36
Rafal.Gaweda
in reply to: REDO10
Errors because of loads to mass conversion of case 17
Rafal Gaweda
Message 36 of 36
Rafal.Gaweda
in reply to: REDO10
correct loads:
Rafal Gaweda
